[gdal-dev] GeomTransform in VRT-file
Dmitriy Baryshnikov bishop.dev at gmail.com
Thu Jul 4 12:58:19 PDT 2013
Hi Jan,
Do you mean this : http://www.gdal.org/gdal_datamodel.html (Affine
GeoTransform srection) or this http://www.gdal.org/gdal_tutorial.html
(Getting Dataset Information section)?
Also, see this:
http://www.gdal.org/classVRTDataset.html#a1531325b71e290b90c8d9cc88bce6c2b
Best regards,
     Dmitriy
04.07.2013 20:12, Jan Hartmann пишет:
> I'm struggling with the order of the Geotransform section in a vrt
> file. I would like to rotate an image, and computed the six parameters
> for the affine transformation. I can transform points exactly, using
> the following formula:
> x2 = a.x1 + b.y1 + c
> y2 = d.x1 + e.y1 + f
> Can anyone tell me what the order is in the GeoTransform section of
> the VRT-file?
> <GeoTransform> c a b f d e </GeoTransform>
> results in an image somewhere in the neighbourhood, but mirrored and
> translated. What is the order of the parameters a-f?
> Jan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
