[gdal-dev] ogr2ogr fail: crtExitProcess
Even Rouault even.rouault at mines-paris.org
Thu Jul 4 14:40:32 PDT 2013
Le jeudi 04 juillet 2013 22:05:26, Hilda Villegas a écrit :
> Thanks for your response. Yes, I'm using gdal 10.0
> Attached is the ENC that I'm using.
Hum, your ogr2ogr command line works for me with different GDAL builds,
including the one available at
http://www.gisinternals.com/sdk/PackageList.aspx?file=release-1310-gdal-1-10-0-
mapserver-6-2-1.zip
If you've compiled GDAL yourself, then it looks like an issue with your build.
Geospatial professional services
http://even.rouault.free.fr/services.html
