[gdal-dev] gdal_merge.py won't load libpng
William Kyngesburye woklist at kyngchaos.com
Fri Jul 5 15:13:05 PDT 2013
Looks like a confused gdal and python installation mess...
If you're using my GDAL framework, it uses my UnixImageIO framework for libpng.  And, the included gdal-python uses the system python.
But according to the error python is looking for python modules (thus gdal-python) in /usr/local.  This implies that the system python is NOT running, but a custom install (is that what anaconda is?), with it's own python module search path.  I'm guessing that the anaconda python (?) is in /usr/local/bin and thus be found before the system python.
PYTHONPATH might work to redirect your custom python to look for the correct gdal-python:
  export PYTHON_PATH=/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages
If not, you'll have to uninstall your custom python (anaconda? homebrew?) so it doesn't override the system python.
On Jul 5, 2013, at 2:39 PM, Dominik Schneider wrote:
> anyone have any suggestions?! I'm at a complete loss how to troubleshoot.
> Dominik Schneider
> o 303.735.6296 | c 518.956.3978
> On Tue, Jul 2, 2013 at 10:52 AM, Dominik Schneider <dominik.schneider at colorado.edu> wrote:
> Hi,
> I am trying to run:
> gdal_merge.py -init -9999 -n 2001 -o MOD09GA.A2012001.h08v05.005.NRTsnow_fraction.tif.1 MOD09GA.A2012001.h08v05.005.NRTsnow_fraction.tif
> The Error:
> Traceback (most recent call last):
>   File "/Library/Frameworks/GDAL.framework/Programs/gdal_merge.py", line 36, in <module>
>     import gdal
>   File "/usr/local/lib/python2.7/site-packages/gdal.py", line 2, in <module>
>     from osgeo.gdal import deprecation_warn
>   File "/usr/local/lib/python2.7/site-packages/osgeo/__init__.py", line 21, in <module>
>     _gdal = swig_import_helper()
>   File "/usr/local/lib/python2.7/site-packages/osgeo/__init__.py", line 17, in swig_import_helper
>     _mod = imp.load_module('_gdal', fp, pathname, description)
> ImportError: dlopen(/usr/local/lib/python2.7/site-packages/osgeo/_gdal.so, 2): Library not loaded: libpng15.15.dylib
>   Referenced from: /usr/local/Cellar/gdal/1.10.0/lib/libgdal.1.dylib
>   Reason: image not found
> Gdal is here:
> > which gdal_merge.py
> I'm completely new gdal but am guessing i've got some confusion between different versions of gdal and python.  I have rgdal installed so at some point in the past I probably installed gdal too? Today I installed gdal with homebrew and also tried the binary from http://www.kyngchaos.com/software:frameworks
> For python I have the system default (2.7) on osx.7.5 and the anaconda installation.
> I should also say, if I load python I am unable to import gdal:
> > python
> Python 2.7.4 |Anaconda 1.5.1 (x86_64)| (default, May  9 2013, 12:12:00)
> [GCC 4.0.1 (Apple Inc. build 5493)] on darwin
> Type "help", "copyright", "credits" or "license" for more information.
> >>> from osgeo import gdal
>   File "<stdin>", line 1, in <module>
> any help would be appreciated.
> Thanks
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
All generalizations are dangerous, even this one.
