[gdal-dev] How can I translate MODIS04_L2 AOT as ENVY Modis conversion toolkit?
yuchan a09550 at gmail.com
Thu Jul 11 08:42:13 PDT 2013
Hello every body.
I've a MODIS04 L2, and I want to extract band
8:Image_Optical_Depth_Land_And_Ocean. I use Quantum GIS to open this band,
because Quantum GIS see this is not coordinates so this allow me to select
projection as below: +proj=utm +zone=50 +ellps=WGS84 +datum=WGS84 +units=m
+no_defs +towgs84=0,0,0.
All I know is that I want to translate to WGS84. This open this band seems
good but when I open this band with ENVI this is better (differents output
images). But I see the Modis Conversion Toolkit use same warp parameters as
Quantum Gis expect it has a parameters ("Numbers of Warp Points").
This is Envi Conversion Toolkit
<http://osgeo-org.1560.x6.nabble.com/file/n5065817/ENVI_MODIS.png>
This is open file HDF with QuantumGis
<http://osgeo-org.1560.x6.nabble.com/file/n5065817/QuantumGIS1.png>
This is open Envi output file with Quantum Gis
<http://osgeo-org.1560.x6.nabble.com/file/n5065817/QuantumGIS_Envi.png>
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-can-I-translate-MODIS04-L2-AOT-as-ENVY-Modis-conversion-toolkit-tp5065817.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
