[gdal-dev] Working with NTF files
Sun Jul 14 16:11:14 PDT 2013
On Sun, Jul 14, 2013 at 2:53 PM, Nikos Alexandris
<nik at nikosalexandris.net>wrote:
> Hi list & apologies for cross-posting.
> In short,
> I am trying to handle ntf files (NITF) as easy as possible -- working with
> some WorldView 01/02 and QuickBird imagery.
> 1) The question is:  how do you correctly import in GRASS-GIS QuickBird &
> WorldView imagery from N(I)TF containers?
Nikos,
Your working solution with gdalwarp seems reasonable.  Is there a problem
with it?  Perhaps you were hoping to do the RPC based warp within GRASS?
> 2) A second, of less importance, question, is:  how important are the
> warnings
> like:  "Warning 1: Unable to save auxilary information in
> /vsisubfile/3884_471349721,10APR13WV020600013APR10075059-
> P1BS-500060446050_05_P003.ntf.aux.xml." ?
This is not important.  I presume you are getting this with JPEG2000
compressed
image streams in NITF?  If you file a bug I might be able to clear this up
but there
are layers of complexity that make it challening.
> My working solution (seems to be),
> is to gdal-warp the SUBDATASET that contains the raster spectral bands
> _and_
> by using the -rpc switch (mentioned in some past post in GDAL-dev's ML
> [19]).
> Otherwise, the resulting warped image is heavily skewed and not ready for
> analysis.  E.g.:
> gdalwarp -rpc NITF_IM:0:10APR13WV020600013APR10075059-
> P1BS-500060446050_05_P003.ntf 10APR13WV020600013APR10075059-
> P1BS-500060446050_05_P003_NorthUp.tif
> This post is, also, sort of a BUMP related to my previous latest message in
> the GDAL-dev-ML's thread entitled  "Can't read NITF images" :-!  I think
> that
> N(I)TF files, no matter whatsoever the status of the related drivers are,
> as
> well as the "feelings" towards favouring it or not, deserves some more
> examples, a page in GRASS-Wiki perhaps, etc.
I'm afraid I'm one of those who neglected that thread.  I thought I saw Even
answer is so I was happy to keep out of it.
I can't speak to how the files should be described in GRASS.  Generally
I'd hope that the value of using GDAL is that GRASS wouldn't need to
talk too much about specific formats.
On the GDAL side we often have special info in trac wiki pages under the
BuildHints page, but in this case the issues are more usage rather than
building so there is no obvious place for user contributions.  The format
pages for NITF do have quite a bit of info.  It is (I think) the only driver
with an "advanced" page.  However, there are many kinds of NITF
files and thus usage patterns that are an issue so it isn't clear how to
handle that in the user docs.
I've skimmed the rest of your post, but I don't have any particular
advice or anything to add.  I do think it is reasonable to correct
such images into a nicer form with gdalwarp before running r.in.gdal.
Best regards,
Frank
> Now, the long story is that,
> I 've been through the list (grass-user, gdal-dev), manuals (grass
> importing
> related stuff & gdal's driver's documentation), well known and easy to find
> pages in GRASS-Wiki, GDAL tutorials, etc.  I haven't found any concrete
> examples on working with NITF images and GFOSS. [**See various links in the
> end]
> I would appreciate any hints (while I am actively searching How To do this
> best) to save time in the quest to find an optimal solution which can be
> scripted to handle various images from the same source.  Unfortunately,
> there
> is no access in GeoTiffs (so far/yet)!
> Set aside the internal compression "obstacle" (JPEG2000) which one can
> overcome using the OpenJPEG driver (or, necessarily some proprietary (?)
> bound
> solution [0, 1, 2, 3]), NITF files that contain multiple SUBDATASETS may
> look
> like:
> # code ###################################################
> gdalinfo -nomd -norat -noct -nofl 10APR13WV020600013APR10075059-
> Driver: NITF/National Imagery Transmission Format
> Files: 10APR13WV020600013APR10075059-P1BS-500060446050_05_P003.ntf
> Size is 35840, 27648
> Coordinate System is `'
> GCP Projection =
> GEOGCS["WGS 84",
>     DATUM["WGS_1984",
>         SPHEROID["WGS 84",6378137,298.257223563,
>             AUTHORITY["EPSG","7030"]],
>         TOWGS84[0,0,0,0,0,0,0],
>         AUTHORITY["EPSG","6326"]],
>     PRIMEM["Greenwich",0,
>         AUTHORITY["EPSG","8901"]],
>     UNIT["degree",0.0174532925199433,
>         AUTHORITY["EPSG","9108"]],
>     AUTHORITY["EPSG","4326"]]
> GCP[  0]: Id=UpperLeft, Info=
>           (0.5,0.5) -> (43.8088888888889,-23.3544444444444,0)
> GCP[  1]: Id=UpperRight, Info=
>           (35839.5,0.5) -> (43.6219444444444,-23.3344444444444,0)
> GCP[  2]: Id=LowerRight, Info=
>           (35839.5,27647.5) -> (43.6225,-23.1958333333333,0)
> GCP[  3]: Id=LowerLeft, Info=
>           (0.5,27647.5) -> (43.8083333333333,-23.2152777777778,0)
> Subdatasets:
>   SUBDATASET_1_NAME=NITF_IM:0:10APR13WV020600013APR10075059-
>   SUBDATASET_1_DESC=Image 1 of 10APR13WV020600013APR10075059-
>   SUBDATASET_2_NAME=NITF_IM:1:10APR13WV020600013APR10075059-
>   SUBDATASET_2_DESC=Image 2 of 10APR13WV020600013APR10075059-
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0,27648.0)
> Upper Right (35840.0,    0.0)
> Lower Right (35840.0,27648.0)
> Center      (17920.0,13824.0)
> Band 1 Block=1024x1024 Type=UInt16, ColorInterp=Gray
>   Overviews: 17920x13824, 8960x6912, 4480x3456, 2240x1728, 1120x864
>   Overviews: arbitrary
> The 1st SUBDATASET is reported as:
> gdalinfo -sd 1 -nomd -norat -noct -nofl 10APR13WV020600013APR10075059-
> [ -- cut -- some Warnings -- ]
> GCP Projection =
> GEOGCS["WGS 84",
>     DATUM["WGS_1984",
> Corner Coordinates:
> The 2nd SUBDATASET is reported as:
> gdalinfo -sd 2 -nomd -norat -noct -nofl 10APR13WV020600013APR10075059-
> Size is 97, 78
> Coordinate System is:
> GEOGCS["WGS 84",
>     DATUM["WGS_1984",
> GeoTransform =
>   43.8096587433111, -0.001954571759259283, -1.803751803795437e-06
>   -23.35525135093495, 0.0002068865740741814, 0.001823593073593144
> Corner Coordinates:
> Upper Left  (  43.8096587, -23.3552514) ( 43d48'34.77"E, 23d21'18.90"S)
> Lower Left  (  43.8095181, -23.2130111) ( 43d48'34.26"E, 23d12'46.84"S)
> Upper Right (  43.6200653, -23.3351834) ( 43d37'12.24"E, 23d20' 6.66"S)
> Lower Right (  43.6199246, -23.1929431) ( 43d37'11.73"E, 23d11'34.60"S)
> Center      (  43.7147917, -23.2740972) ( 43d42'53.25"E, 23d16'26.75"S)
> Band 1 Block=97x1 Type=Byte, ColorInterp=Undefined
> Likewise, reporting on a Multi-Spectral NTF container, the 2nd SUBDATASET
> is
> the Spatial Reference System information.
> Unfortunately, though expected, r.in.gdal complains about the missing
> projection info for the 1st SUBDATASET.
> r.in.gdal in=NITF_IM:0:10APR13WV020600013APR10075059-
> P1BS-500060446050_05_P003.ntf out=m_sd_1
> ERROR: Projection of dataset does not appear to match current location.
>        Location PROJ_INFO is:
>        proj: ll
>        datum: wgs84
>        ellps: wgs84
>        no_defs: defined
>        Import dataset PROJ_INFO is:
>        cellhd.proj = 0 (unreferenced/unknown)
>        You can use the -o flag to r.in.gdal to override this check and use
>        the location definition for the dataset.
>        Consider generating a new location from the input dataset using the
>        'location' parameter.
> Adding the "-o" flag, gets to the next error:
> P1BS-500060446050_05_P003.ntf out=m_sd_1 -o
> WARNING: Over-riding projection check
> ERROR: Illegal latitude for North
> Adding the "-l" switch, takes too much time "waiting" in 0% for the import
> process.  Now, the GCP's are given in the 2nd SUBDATASET(s).  Is there any
> way
> to avoid usnig "r.region" and make the long story short, just by using some
> gdal-* magic?
> Using gdalwarp to go NorthUp:
> #################################################### code #
> gdalwarp -of NITF -co "ICORDS=G" NITF_IM:0:10APR13WV020600013APR10075059-
> P1BS-500060446050_05_P003_NorthUp.ntf
> allows for imoprting the image via r.in.gdal.   However, this image is
> obviously and heavily skewed/shifted.  Using r.region doesn't make any
> sense...
> since the image boundaries coincide!
> gdalinfo -nomd -noct -norat -nofl -nogcp 10APR13WV020600013APR10075059-
> M1BS-500060446050_05_P003_NorthUp.tif
> Corner Coordinates:
> Upper Left  (  43.6218649, -23.1956837) ( 43d37'18.71"E, 23d11'44.46"S)
> Lower Left  (  43.6218649, -23.3543246) ( 43d37'18.71"E, 23d21'15.57"S)
> Upper Right (  43.8088360, -23.1956837) ( 43d48'31.81"E, 23d11'44.46"S)
> Lower Right (  43.8088360, -23.3543246) ( 43d48'31.81"E, 23d21'15.57"S)
> and minor differences when gdal-warping in to a NITF file
> Corner Coordinates:
> Upper Left  (  43.6219339, -23.1955450) ( 43d37'18.96"E, 23d11'43.96"S)
> Lower Left  (  43.6219339, -23.3544550) ( 43d37'18.96"E, 23d21'16.04"S)
> Upper Right (  43.8088994, -23.1955450) ( 43d48'32.04"E, 23d11'43.96"S)
> Lower Right (  43.8088994, -23.3544550) ( 43d48'32.04"E, 23d21'16.04"S)
> After importing, one band reports
> r.info -g M1BS_from_TIF.1
> north=-23.1956836847222
> south=-23.3543246272222
> east=43.8088360363889
> west=43.6218648544444
> The corner coordinates are practically identical.  Hence, it doesn't look
> like
> boundary (re-)definition/correction is required for these rasters.
> So, how do you go about your NITF images?
> The only "nice-working" attempt so far, is when I extacted a specific
> fragment
> out of the Multi-Spectral container, for example, using the "-te" switch
> while
> warping, i.e. (using values, of course, in place of West, South, North and
> East):
> gdalwarp -s_srs 'epsg:4326' -te West South North East
> 03APR13WV010500013APR03073141-P1BS-500060446050_03_P003.ntf test.tif
> These small fragments coincide perfectly with some vectorised area of
> intere
> st.
> And, finally, and fortunately, adding the "-rpc" magic, seems to do the
> trick.
> Importing an rpc-warped image in GRASS, looks, after some cross-checks,
> nice
> Any other solutions?
> Thanks, Nikos
> [0]
> http://www.jpeg.org/faq.phtml?action=show_answer&question_id=q3f042a68b1081
> [1] <http://trac.osgeo.org/gdal/wiki/ECW>
> [2] <http://trac.osgeo.org/gdal/wiki/JasPer>
> [3] <http://trac.osgeo.org/gdal/wiki/JP2KAK>
> [4] <http://trac.osgeo.org/gdal/wiki/MrSID>
> NITF and GDAL
> [5] <http://www.gdal.org/frmt_nitf.html>
> [6] <http://www.gdal.org/frmt_nitf_advanced.html>
> NITF Related posts (even a bit)
> [7] <http://lists.maptools.org/pipermail/fwtools/2008-March/001193.html>,
> 2008, refers also to license stuff.
> [8] <
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-Can-t-read-NITF-image-td5064590.html
> [9] <http://lists.osgeo.org/pipermail/gdal-dev/2012-April/032431.html>
> [10] <http://web.archiveorange.com/archive/v/H2CPnHaFxXHV9S1zxqmE>
> [11] <http://lists.osgeo.org/pipermail/grass-user/2000-May/003502.html>,
> very
> old!
> [12] <http://lists.osgeo.org/pipermail/grass-user/2006-March/033353.html>,
> old
> [13] <http://lists.osgeo.org/pipermail/grass-user/2006-March/033300.html>,
> old
> [14] <
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-NITF-with-MultiDataSet-td5050649.html>,
> "Try building a vrt with the NITF datasets."
> [15] <http://www.mail-archive.com/gdal-dev@lists.osgeo.org/msg02376.html>,
> refers to "-co".
> [16] <http://marc.info/?l=gdal-dev&m=121323053222339&w=2>
> [17] <http://osdir.com/ml/gdal-development-gis-osgeo/2009-01/msg00044.html
> about compression/compressed output.
> Advanced coding discussions
> [18] <
> http://osgeo-org.1560.x6.nabble.com/NITF-image-metadata-domain-field-in-GDAL-SUBDATASETS-td3762940.html
> [19] <
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-How-to-use-RPC-Metadata-from-NITF-Files-in-a-MapServer-TileIndex-td4981951.html>,
> "The images also
> have rpc metadata and using the -rpc option in gdalwarp reprojects them
> quite
> well."
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130714/0479aa41/attachment-0001.html>
