[gdal-dev] Working with NTF files
Eli Adam eadam at co.lincoln.or.us
Mon Jul 15 09:55:43 PDT 2013
> No (except that I left this option as the "final attempt" of many tests --
> working with some >1GB images here, so it took me hours... :D).  Your
> confirmation, though, is highly useful!
Sometimes to avoid materializing large intermediate datasets on disk, a VRT
can be used.  I'm not sure if this would be useful in your case.
> On the GDAL side we often have special info in trac wiki pages under the
> BuildHints page, but in this case the issues are more usage rather than
> building so there is no obvious place for user contributions.  The format
> pages for NITF do have quite a bit of info.  It is (I think) the only
driver
> with an "advanced" page.  However, there are many kinds of NITF
> files and thus usage patterns that are an issue so it isn't clear how to
> handle that in the user docs.
I and others have put GDAL usage notes here,
http://trac.osgeo.org/gdal/wiki/CodeSnippets
Best Regards, Eli
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130715/6d52ebe9/attachment.html>
