[gdal-dev] gtiff with internal mask
Duarte Carreira DCarreira at edia.pt
Tue Jul 16 03:29:37 PDT 2013
I'm trying to create gtiffs with transparent areas where there are voids between my original images.
I have successfully done it by using an alpha band but this process created 3x larger images. I think partly because of an additional 4th band and partly because I cannot use ycbcr to compress with jpeg. So I thought of using internal masks expecting to get smaller images but cannot get it to work.
When converting from the rgba image using -mask 4 I cannot "see" the transparency and get black areas:
gdal_translate -b 1 -b 2 -b 3 -ma sk 4 --config GDAL_TIFF_INTERNAL_MASK YES test_alpha.tif test_internalmask.tif
I tried looking at the images using qgis and paint.net.
Any hints or help appreciated.
Thanks,
Duarte
Duarte Carreira
Diretor | Dep. Informa??o Geogr?fica e Cartografia
www.edia.pt<http://www.edia.pt>
www.alqueva.com.pt<http://www.alqueva.com.pt>
Tel. +351 284315100
[http://www.edia.pt/edia/images/edia_logo2.gif]<http://www.edia.pt>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130716/76f16048/attachment-0001.html>
