[gdal-dev] MSSQLSpatial support for non-spatial tables
Tamas Szekeres szekerest at gmail.com
Wed Jul 17 05:06:13 PDT 2013
Jeremy,
Thanks for that, I'll review the patch shortly.
Best regards,
Tamas
2013/7/17 Jeremy Palmer <JPalmer at linz.govt.nz>
> Hi gdal devs,
> I've attached a patch to http://trac.osgeo.org/gdal/ticket/5155 to
> support listing, reading and writing of non-spatial tables within the
> MSSQLSpatial driver. The change also allows the user to set the
> MSSQLSPATIAL_LIST_ALL_TABLES=YES configuration option to be able to read
> and list non spatial tables.
> Let me know if I need to do anything else to get the patch committed to
> trunk.
> Cheers,
> Jeremy
> This message contains information, which is confidential and may be
> subject to legal privilege. If you are not the intended recipient, you must
> not peruse, use, disseminate, distribute or copy this message. If you have
> received this message in error, please notify us immediately (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130717/359bd74f/attachment.html>
