[gdal-dev] [BULK] Re: Dissolve shapefile using GDAL/OGR
Dan Strobridge dan.strobridge at westonsolutions.com
Fri Jul 19 11:14:05 PDT 2013
Thanks Evan.  I will try the workaround and use it until GDAL 1.10 has been incorporated into OSGeo4W.
Since you’ve brought up the OSGeo4W installer… mine says my gdal library is current (1.9.2-2) bu when I launch the shell I see the following, which suggests an older version is actually getting loaded.  You don’t happen to know how to resolve this, do you?
OSGEO4W home is C:\OSGeo4W\
                   -={ OSGeo4W Shell Commands }=-
find: unable to access ".exe": The system cannot find the file specified.
find: unable to access ".bat": The system cannot find the file specified.
GDAL 1.7.3, released 2010/11/10
Thanks so much,
Dan
From: Even Rouault [via OSGeo.org] [mailto:ml-node+s1560n5067676h80 at n6.nabble.com]
Sent: Friday, July 19, 2013 2:01 PM
To: Strobridge, Daniel M.
Subject: [BULK] Re: Dissolve shapefile using GDAL/OGR
Le vendredi 19 juillet 2013 17:23:24, Dan Strobridge a écrit :
> I'm getting the same ST_Union error as Benicio but I know I have Spatialite
> (v.3.0.1-2), SQLite (3.7.10-2), and Geos (3.3.8-1) from my OSGeo4W install
> on Win7.  I also tried using the GUnion function, which appears to have
> been replaced by ST_Union at 3.0.0.  In fact, none of the  spatial
> operator functions
> <http://www.gaia-gis.it/spatialite-3.0.0-BETA/spatialite-sql-3.0.0.html#p14
> > ) appear to work.
> This is the first time I've tried implementing anything other than a format
> conversion or a simple select query using ogr.  Could anyone suggest an
> ogr2ogr command to me that would test whether it's a Spatialite/Geos
> installation problem or simply a bug?
Dan,
If http://trac.osgeo.org/osgeo4w/wiki/pkg-gdal is up-to-date, the current
version of GDAL in OSGeo4W would be GDAL 1.9.X. The SQLite dialect is a new
function of GDAL 1.10 ...
A workaround is to translate your shapefile into a temporary spatialite DB, and
then do the conversion to GMT with the SQL query.
Best regards,
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
gdal-dev mailing list
[hidden email]</user/SendEmail.jtp?type=node&node=5067676&i=0>
http://lists.osgeo.org/mailman/listinfo/gdal-dev
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/gdal-dev-Dissolve-shapefile-using-GDAL-OGR-tp5036930p5067676.html
To unsubscribe from [gdal-dev] Dissolve shapefile using GDAL/OGR, click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5036930&code=ZGFuLnN0cm9icmlkZ2VAd2VzdG9uc29sdXRpb25zLmNvbXw1MDM2OTMwfDIwMDMxMDQ3Mjk=>.
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
CONFIDENTIALITY:  This email and attachments may contain information which is confidential and proprietary.  Disclosure or use of any such confidential or proprietary information without the written permission of Weston Solutions, Inc. is strictly prohibited.  If you received this email in error, please notify the sender by return e-mail and delete this email from your system.  Thank you.
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Dissolve-shapefile-using-GDAL-OGR-tp5036930p5067681.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130719/76834a7a/attachment.html>
