[gdal-dev] [BULK] Re: Dissolve shapefile using GDAL/OGR
Dan Strobridge dan.strobridge at westonsolutions.com
Thu Jul 25 12:47:07 PDT 2013
Sorry, I meant Even (not Evan).  Another workaround I found is the dissolve
polygons tool in SAGA (instaled from OSGeo4W).  I found this tool very handy
since SAGA has a command line option and this specific tool allows up to
three dissolve fields to be specified.  My syntax was:
saga_cmd shapes_polygons "Polygon Dissolve" -POLYGONS=infile.shp
-DISSOLVED=outfile.shp -FIELD_1=combo -FIELD_2=zone -FIELD_3=val -DISSOLVE=0
Dan
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Dissolve-shapefile-using-GDAL-OGR-tp5036930p5068800.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
