[gdal-dev] Working with NTF files
lpinner Luke.Pinner at environment.gov.au
Mon Jul 29 20:12:29 PDT 2013
A workaround to your 2nd question is to set the GDAL_PAM_PROXY_DIR
environment variable, either permanently or on the commandline before you
call gdalinfo.
set GDAL_PAM_PROXY_DIR=%TEMP%
gdalinfo -stats some.ntf
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Working-with-NTF-files-tp5066312p5069520.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
