[gdal-dev] Reading error with dwg and dxf files
Xian Chen chenxian at walkinfo.com.cn
Wed Jul 31 01:42:28 PDT 2013
Hi all,
I encountered an error when reading the attached dwg file using OGR. The
last part is supposed to be a clockwise big circle arc, but is translated
into a counterclockwise circle arc.
I then converted the file into dxf and still have the error. Can anyone
please help me out?
Best regards,
Xian
Curvelines.dwg
<http://osgeo-org.1560.x6.nabble.com/file/n5069826/Curvelines.dwg>
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Reading-error-with-dwg-and-dxf-files-tp5069826.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
