[gdal-dev] Asking about Convert Dgn to Shp and OGRLayer::SetSpatialFilter
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Sun Jun 2 03:44:19 PDT 2013
taibc <taibc_coltech <at> yahoo.com> writes:
> Hi,
> I used the this function:
> http://osgeo-org.1560.x6.nabble.com/file/n4989766/Source1.cpp
> <http://osgeo-org.1560.x6.nabble.com/file/n4989766/Source1.cpp>
> to convert my dgn file to shp file. But, after converting, I can't select
> the small polygon (that is contained in another polygon, I used ArcMap to
> test this). Please see my image for demo:
> <http://osgeo-org.1560.x6.nabble.com/file/n5057280/image.png>
> Are there anyone know how to fix it ?
I fear that with this much of information, no. It would be easier if you
could sent a small sample of your source data and an exact description about
what you did so that someone could repeat it.
-Jukka Rahkonen-
