[gdal-dev] no translation for Mercator to PROJ.4
rawalpundi guillmercier at yahoo.fr
Mon Jun 3 15:14:34 PDT 2013
hello,
i'm trying to gdalwarp a google map tile geotiff
its SRS is a 3857.prj
PROJCS["WGS 84 / Pseudo-Mercator",GEOGCS["Popular Visualisation
CRS",DATUM["D_Popular_Visualisation_Datum",SPHEROID["Popular_Visualisation_Sphere",6378137,0]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Mercator"],PARAMETER["central_meridian",0],PARAMETER["scale_factor",1],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["Meter",1]]
unfortunately this proj is not supported by my framework
so I'm trying to convert it to a standard WGS84 proj :
gdalwarp -t_srs WGS84
but I get the following error :
ERROR6 : No translation for Mercator to PROJ.4 format is known
any idea of what it wrong ?
thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/no-translation-for-Mercator-to-PROJ-4-tp5057584.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
