[gdal-dev] Clipping imprecision with gdal_translate
Ari Jolma ari.jolma at gmail.com
Tue Jun 4 00:35:43 PDT 2013
JM,
Looks to me that GDAL has clipped to the nearest pixel boundaries and
not to the window you have provided. This is probably a feature. Maybe
gdalwarp would do the kind of resampling you wish, but I'm not sure.
Regards,
Ari
On 06/03/2013 03:37 PM, JM wrote:
> Hello List.
> At first i wanna thanks for the great work you are doing with the gdal
> library. It is a source of great tools and opportunities for spatial
> issues which whom i involed in.
> Among others i am using the commandline tool gdal_translate for
> clipping raster files via the following example command:
>                 gdal_translate -projwin 13.6666664938 53.2000002428
> 13.8333334784 53.1000017686 source.tif target.tif
> The source tif is already georeferenced (EPSG:4326). I would now
> assume that the boundingbox of the following GTiff is somethink like this:
>                 Lower Left: 13.6666664938 53.1000017686
>                 Upper Right: 13.8333334784 53.2000002428
> Instead it is something like this (the full gdalinfo dialog you can
> see in the attach to this mail):
>                 Lower Left: 13.6666610463 53.1000244672
>                 Upper Right: 13.8333191458 53.2000151873
> So there is a small imprecision in the clipping result. My question is
> now if this imprecision is normal (maybe a result of rounding
> operations within the clipping process) or if i do something wrong (do
> i miss something in my command).
> I am using libgdal1 version 1.9.0-3.1ubunut1. Looking forward to
> hearing from you.
> Kind regards,
> JM
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130604/aaac0597/attachment.html>
