[gdal-dev] with poppler error
Even Rouault even.rouault at mines-paris.org
Thu Jun 6 14:37:40 PDT 2013
Le jeudi 06 juin 2013 23:14:35, Joaquim Luis a écrit :
> Hi,
> I'm having this error when building with poppler. It used to build
> before but for the doubts I rebuild poppler (from the git repo) but the
> error persists.
> C:/programs/compa_libs/poppler_GIT\poppler/SplashOutputDev.h(164) :
> error C2061: syntax error : identifier 'SplashThinLineMode'
> error C2059: syntax error : ')'
> error C2143: syntax error : missing ')' before ';'
> c1xx : fatal error C1903: unable to recover from previous error(s);
> stopping compilation
I've just tried on Linux with latest poppler git, and GDAL compiles fine. I can
see that SplashThinLineMode is an enumeration defined in
poppler/splash/SplashTypes.h. Perhaps you should check if that exists in it.
Perhaps an installation problem of poppler headers on Windows... ? I can see
that the enumeration is new in poppler 0.23/git w.r.t poppler 0.22.
> Joaquim
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
