[gdal-dev] Bad result when writing into KML without -t_srs
Andre Joost andre+joost at nurfuerspam.de
Thu Jun 6 21:09:15 PDT 2013
Am 07.06.2013 01:26, schrieb Jukka Rahkonen:
> The result is good if I add parameter -t_srs epsg:4326. However, this should
> be unnecessary with KML because it is always EPSG:4326 and also the driver
> manual page http://www.gdal.org/ogr/drv_kml.html claims the same in the text
> and in the examples.
+1, the same should go for the GPX driver.
Greetings,
André Joost
