[gdal-dev] How to re-project EPSG:4326 to polar projection EPSG:3411
ven otrov at hush.ai
Fri Jun 7 16:54:55 PDT 2013
Hello,
I have global tiff file in EPSG:4326 and wanted to re-project in EPSG:3411
(http://spatialreference.org/ref/epsg/3411/).
I used this command:
"gdalwarp -s_srs EPSG:4326 -t_srs EPSG:3411 global.tif polar.tif"
which resulted in tiff image with large black hole in the middle and some
gray content outside this black circle. I was hoping obviously for opposite
- projection inside circle and black content outside, so I guess I failed at
some point but not sure where. Can anyone suggest what may be the problem
here?
I use gdal 1.10.0  on Windows
Thanks in advance
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-re-project-EPSG-4326-to-polar-projection-EPSG-3411-tp5058811.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
