[gdal-dev] gml driver : access to the db temporary
Andrea Peri aperi2007 at gmail.com
Sun Jun 9 08:58:55 PDT 2013
On 07/06/2013, Ari Jolma wrote:
>On 06/06/2013 09:24 PM, Andrea Peri wrote:
>>* Hi,*>>**>>* As reported in the GML driver page:*>>**>>* when using the  GML_SKIP_RESOLVE_ELEMS HUGE method to resolve the GML.*>>* It will produce firstly a file-system based DBMS.*>>**>>* I don't see this dbms file so probably itis removed fter it use.*>>**>>* I'm interest to see its information. So there is a workaround to avoid *>>* this remove ?*>
>If that is the case, then possibly you can avoid it by using a
>programmatic interface to GDAL.
>Ari
Thx for response.
Meanwhile I spoke with on of the author of GML topology driver reader and
understand that the information in the temporary db was not interesting to
me.
I was interest in the PAL topology information available in the topology
GML .
But it is not available in that file.
So I will do a my specific parser to extract this information from GML.
Regards,
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130609/9f3192eb/attachment.html>
