[gdal-dev] cannot access GFT recently via QGIS and OGR
Mon Jun 10 09:08:30 PDT 2013
Maning,
Could you try GDAL 1.10.0 which has an upgraded GFT (Google Fusion Tables)
driver.  There were some changes in how the login stuff worked in January
or so on the google side.
Make sure you read over the format driver page for details of usage.
  http://www.gdal.org/ogr/drv_gft.html
Best regards,
Frank
On Jun 9, 2013 7:54 PM, "maning sambale" <emmanuel.sambale at gmail.com> wrote:
> I have a vrt with the following contents:
> (email and password redacted)
> <OGRVRTDataSource>
>   <OGRVRTLayer name="data">
>     <SrcDataSource>
>       GFT:email=redacted password=redacted
>     </SrcDataSource>
>     <SrcLayer>data</SrcLayer>
> </OGRVRTLayer>
> This vrt used to work and I can view and edit the data.  But recently,
> I got this error.
> ogrinfo -ro census.vrt
> INFO: Open of `census.vrt'
>       using driver `VRT' successful.
> ERROR 1: HTTP error code : 400
> ERROR 1: HTML error page returned by server
> 1: data
> Using GDAL 1.9.2, released 2012/10/08
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130610/139203b4/attachment.html>
