[gdal-dev] geographic vs projected coordinate system
Jean-Claude Repetto jrepetto at free.fr
Mon Jun 10 09:06:01 PDT 2013
Le 10/06/2013 17:44, Andre Joost a écrit :
> What you see on the screen, is in fact projected, but with a simple one
> degree = one unit on the screen projection. The extent of that map is
> still +/- 180°/90°
This projection is the same as "Plate carrée" (EPSG:32663), except that
the units are degrees instead of meters.
