[gdal-dev] geographic vs projected coordinate system
Martin Feuchtwanger feumar at shaw.ca
Mon Jun 10 23:33:28 PDT 2013
Some of Phil's and Andre's words require correction:
Just because it is so simple mathematically, the Plate Carree (or
equi-rectangular) projection is no less of a projection than others.
Like /all /projections, it has its distortions and yet it preserves some
geometrics. It is in the class known as "equidistant" projections. In
this particular case, scale is preserved along the equator /and/ at all
points on the map in a direction perpendicular to the equator. (Pretty
impressive for something so simple, eh?)
Martin Feuchtwanger  feumar at shaw.ca  604-254-0361
http://members.shaw.ca/geomatics.developer
On 10/06/2013 2:22 PM, Phil Scadden wrote:
> There is nothing to stop you however from treating lat/long as
> rectangular coordinates and using that as a "projection". The
> projection figure is Plate Carree and /this has no redeeming
> cartographic features as a projection/.
On 10/06/2013 8:44 AM, Andre Joost wrote:
> What you see on the screen, is in fact projected, but with a simple
> one degree = one unit on the screen projection. The extent of that map
> is still ± 180°/90°
> /This "projection" has none of the benefits usual projection have,
> like true areas, true angles or true lenghts. /
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130610/b487960a/attachment.html>
