[gdal-dev] bugs: 2 examples of incorrect behaviour by gdal_rasterize with zero-polygon valid query result.
Graeme B. Bell grb at skogoglandskap.no
Wed Jun 12 10:58:20 PDT 2013
Also:
(using -init 255 will produce a TIFF with suitable nodata values in the second scenario I described, as a workaround.
However, gdal_rasterize still does not produce correct command line output in this situation, and also it should not be necessary for users to manually add a -init option and manually synchronise the value with the -a_nodata value to ensure valid output from gdal_rasterize)
On Jun 12, 2013, at 7:50 PM, Graeme Bell <grb at skogoglandskap.no> wrote:
> Summary:
> I noticed that gdal_rasterize invents data values instead of burning nodata values, incorrectly, in what is probably a common situation - a valid query returning geometry columns but zero polygon rows.
> Command line output suggests that nothing is being done, yet a GeoTIFF with data values is silently rendered in the background.
