[gdal-dev] bugs: 2 examples of incorrect behaviour by gdal_rasterize with zero-polygon valid query result.
Graeme B. Bell grb at skogoglandskap.no
Thu Jun 13 00:57:12 PDT 2013
> If you feel strong about that, you can file a ticket in Trac about that. Your
> proposal makes sense, although I suspect there could be use cases where it
> wouldn't be desirable, but I can't find them right now...
Thanks. Now logged in trac, #5115
Graeme.
