[gdal-dev] GDAL formats list order
Jorge Arévalo jorgearevalo at libregis.org
Mon Jun 17 09:14:38 PDT 2013
Hi Ivan,
Fine, that makes sense. So, experience and technical reasons qualify one driver to be up or down in the list. Thanks for the response.
Jorge Arevalo
Freelance developer
http://www.krop.com/jorgearevalo
http://about.me/jorgeas80
Enviado con Sparrow (http://www.sparrowmailapp.com/?sig)
El sábado 15 de junio de 2013 a las 13:09, Ivan Lucena escribió:
> Hi Jorge
> "Arbitrariness is a term given to choices and actions
> subject to individual will, judgment or preference, based
> solely upon an individual's opinion or discretion."
> Wikipedia
> That's sounds about right.
> There are several different cases and reason for a driver
> be moved up or down on that list. For example, if a
> format is not safely identified, if it doesn't have a MIME
> header, and if we have cases where it catches somebody
> else files, we move it down on the list.
> > -------Original Message-------
> > From: Jorge Arévalo <jorgearevalo at libregis.org (mailto:jorgearevalo at libregis.org)>
> > To: gdal-dev at lists.osgeo.org (mailto:gdal-dev at lists.osgeo.org)
> > Subject: [gdal-dev] GDAL formats list order
> > Sent: Jun 14 '13 18:56
> > Hello,
> > I read at
> http://trac.osgeo.org/gdal/wiki/GDAL20Changes that
> GDAL formats, when calling gdalinfo --formats, "are
> returned in a meaningful order - the order they are tried -
> which is important to know sometimes".
> > I see at
> http://trac.osgeo.org/gdal/browser/tags/1.10.0/gdal/frmts/
> gdalallregister.cpp several calls to GDALRegister_X, in
> what looks like an arbitrary order to me. Seems to have
> "groups". Apart from that, older drivers first?
> > Is there any reason to choose that order?
> > Many thanks in advance,
> > Jorge Arevalo
> > Freelance developer
> > Enviado con Sparrow
> _____________________________________________
> __
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
