[gdal-dev] ERDAS/Intergraph ECW/JP2 compile problem in 1.10.0
Fri Jun 21 11:32:00 PDT 2013
Scott,
It worked fine for me with trunk.  At that point I see:
if ECWSDK_VERSION<50
    Error = CNCSJP2Box::UnParse(JP2File, Stream);
#else
    Error = CNCSSDKBox::UnParse(JP2File, Stream);
#endif
In my nmake.local file I have:
ECWDIR  =       "c:/build/pkg/ERDAS ECW JPEG2000 Read 4.3 SDK"
ECWFLAGS =      -DECWSDK_VERSION=43 \
                -I$(ECWDIR)\include \
                -I$(ECWDIR)\include/NCSECW/api
-I$(ECWDIR)\include/NCSECW/jp2 \
                -I$(ECWDIR)\include/NCSECW/ecw
ECWLIB  =       $(ECWDIR)\lib\vc90\win32\NCSEcw4_RO.lib \
                $(ECWDIR)\lib\vc90\win32\NCSUtil4.lib \
                $(ECWDIR)\lib\vc90\win32\NCScnet4.lib
ECW_PLUGIN = YES
I'd suggest confirming that you have ECWSDK_VERSION=43 set in the ECWFLAGS
setting you are using.
I'll try and incorporate the warning fixes into trunk.
Best regards,
Frank
On Fri, Jun 21, 2013 at 8:50 AM, Reynolds, Scott <scott at agi.com> wrote:
>  Hi,****
> I’m having trouble compiling GDAL 1.10.0 on Windows with the ERDAS ECW/JP2
> Read/Write SDK v4.3.6.25.****
> Thanks,****
> Scott****
> jp2userbox.cpp****
> jp2userbox.cpp(133) : error C2664: 'NCS::JP2::CBox::UnParse' : cannot
> convert parameter 1 from 'NCS::SDK::CFileBase' to 'NCS::JP2::CFile &'****
> NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual
> Studio 9.0\VC\BIN\cl.EXE"' : return code '0x2'****
> Stop.****
> NMAKE : fatal error U1077: 'for' : return code '0x1'****
> Stop.****
> Studio 9.0\VC\BIN\nmake.EXE"' : return code '0x2'****
> Stop.****
> I’ve also made changes to a couple of files to eliminate warnings in
> VS2008:****
> ecwcreatecopy.cpp****
> 944c944****
> <         m_OStream.Access( fpVSIL, TRUE, bSeekable, pszFilename, 0, -1 );
> >         m_OStream.Access( fpVSIL, TRUE, (BOOLEAN)bSeekable, pszFilename,
> 0, -1 );****
> gdal_ecw.h****
> 370c370****
> <                 GByte prevBuffer[] = { nCOMLength >> 8, nCOMLength &
> 0xff };****
> >                 GByte prevBuffer[] = { (GByte)(nCOMLength >> 8),
> (GByte)(nCOMLength & 0xff) };****
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130621/06ddfc3d/attachment-0001.html>
