[gdal-dev] gcps2wld not finding GCPs
Wolfgang16 wonic at t-online.de
Sat Jun 22 11:21:26 PDT 2013
I am a beginner in GDAL and try to find out what works and what does not
work. I have installed the new ver. 1.10 on Windows XP SP3 and I am
especially interested in the new MAP driver. With the gcps2wld.py utility I
found a behaviour which I cannot explain. On some .map files it prints out
an worldfile as expected, on others it does not:
If I do
gcps2wld.py L-37-143-A.map
the answer is
No GCPs found on file C:\maps\50000\L-37-143-A.map
In contrast to this
gdalinfo -noct L-37-143-A.map
prints out a geotransform
GeoTransform =
  4563916.403948909, 4.777318174663853, 4.051208486634609e-013
  5487310.512072737, -8.102416973269218e-013, -4.760840630639994
results in a worldfile
4.7773181747
-0.0000000000
0.0000000000
-4.7608406306
4563918.7926079957
5487308.1316524222
which differs by half a pixel, but this is not my point. May be it can be
explained by point vs area style.
My question is: why doesn't gcps2wld find any gcps in the appended map file?
Thanks
Wolfgang
OziExplorer Map Data File Version 2.2
1 ,Map Code,
WGS 84,,   0.0000,   0.0000,WGS 84
Reserved 1
Reserved 2
Magnetic Variation,,,E
Map Projection,Mercator,PolyCal,No,AutoCalOnly,No,BSBUseWPX,No
Point01,xy,    0,    0,in, deg,  44, 20.0037,N,  40, 59.9015,E, grid,   ,
,           ,N
Point02,xy, 5826, 5424,in, deg,  44,  9.9996,N,  41, 14.9030,E, grid,   ,
,           ,N
Point03,xy,    0, 5424,in, deg,  44,  9.9996,N,  40, 59.9015,E, grid,   ,
,           ,N
Point04,xy, 5826,    0,in, deg,  44, 20.0037,N,  41, 14.9030,E, grid,   ,
,           ,N
Point05,xy, 2913, 2712,in, deg,  44, 15.0052,N,  41,  7.4023,E, grid,   ,
,           ,N
Point06,xy, 2913,    0,in, deg,  44, 20.0037,N,  41,  7.4023,E, grid,   ,
,           ,N
Point07,xy,    0, 2712,in, deg,  44, 15.0052,N,  40, 59.9015,E, grid,   ,
,           ,N
Point08,xy, 5826, 2712,in, deg,  44, 15.0052,N,  41, 14.9030,E, grid,   ,
,           ,N
Point09,xy, 2913, 5424,in, deg,  44,  9.9996,N,  41,  7.4023,E, grid,   ,
,           ,N
Point10,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point11,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point12,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point13,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point14,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point15,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point16,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point17,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point18,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point19,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point20,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point21,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point22,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point23,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point24,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point25,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point26,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point27,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point28,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point29,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Point30,xy,     ,     ,in, deg,    ,        ,N,    ,        ,W, grid,   ,
,           ,N
Projection Setup,,,,,,,,,,
Map Feature = MF ; Map Comment = MC     These follow if they exist
Track File = TF      These follow if they exist
Moving Map Parameters = MM?    These follow if they exist
MM0,Yes
MMPNUM,4
MMPXY,1,0,0
MMPXY,2,5826,0
MMPXY,3,5826,5424
MMPXY,4,0,5424
MMPLL,1,  40.998359,  44.333395
MMPLL,2,  41.248384,  44.333395
MMPLL,3,  41.248384,  44.166660
MMPLL,4,  40.998359,  44.166660
MM1B,3.426282
LL Grid Setup
LLGRID,No,No Grid,Yes,255,16711680,0,No Labels,0,16777215,7,1,Yes,x
Other Grid Setup
GRGRID,No,No Grid,Yes,255,16711680,No Labels,0,16777215,8,1,Yes,No,No,x
MOP,Map Open Position,0,0
IWH,Map Image Width/Height,5826,5424
View this message in context: http://osgeo-org.1560.x6.nabble.com/gcps2wld-not-finding-GCPs-tp5061752.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
