[gdal-dev] append mode in postgresql
Yves Jacolin (Free) yjacolin at free.fr
Wed Mar 6 06:38:11 PST 2013
Hello,
I am trying to import EDIGEO files in append mode. The doc said to use -append
flag with ogr2ogr commande.
ogr2ogr -gt 65536 -f "PostgreSQL" "PG:dbname=test_edigeo  host='localhost'" -
lco "GEOMETRY_NAME=the_geom" -lco "SCHEMA=test" -lco "OVERWRITE=YES" -nln
EDIGEO_parcelle  E0001.THF PARCELLE_id
=> ok
ogr2ogr -append -update -gt 65536 -f "PostgreSQL" "PG:dbname=test_edigeo
host='localhost'" -lco "GEOMETRY_NAME=the_geom" -lco "SCHEMA=test" -nln
EDIGEO_parcelle  E0002.THF PARCELLE_id
=> nok I get this error message:
ERROR 1: Layer test.edigeo_parcelle already exists, CreateLayer failed.
Use the layer creation option OVERWRITE=YES to replace it.
ERROR 1: Terminating translation prematurely after failed
translation of layer PARCELLE_id (use -skipfailures to skip errors)
Postgresql log file shows:
2013-03-06 15:35:44 CET LOG:  could not receive data from client: Connection
reset by peer
2013-03-06 15:35:44 CET LOG:  unexpected EOF on client connection
and other information which doesn't seem interesting to me.
Any idea whe append mode is not wroking in my test?
Thanks,
Y.
