[gdal-dev] WFS Axis order issue with projected coordinate system
Jeremy Palmer
JPalmer at linz.govt.nz
Wed Mar 6 10:12:54 PST 2013
Thanks Even.
So does this ticket account for this problem?
http://trac.osgeo.org/gdal/ticket/4329
Or do changes need to be applied in the WFS driver as well?
Yes the ISO/OGC people have made my job very hard here in NZ. As NZ's leading geospatial government department LINZ is tasked with pushing OGC standards to get interoperability going. But with all of NZ's 50+ projections being defined as Northing, Easting it's making it very hard to push with users. Because most WFS service talk the highest available version by default, it hard to get users to use and understand why they must use version 1.0.0. BTW it was a mistake that the axis order was set as North, East for NZ projections. In the EPSG submission it was not explicitly specified, rather EPSG inferred it!
________________________________________
From: Even Rouault [even.rouault at mines-paris.org]
Sent: Sunday, 3 March 2013 9:52 p.m.
To: gdal-dev at lists.osgeo.org
Cc: Jeremy Palmer
Subject: Re: [gdal-dev] WFS Axis order issue with projected coordinate system
> Funny thing is ogrinfo reports the SRS with the correct axis order.
> Of course I can add "SRSNAME=EPSG:2193" to the URL, but I'd rather the GDAL
> internals were working correctly.
This is http://trac.osgeo.org/gdal/ticket/4329
In short, the WFS/GML drivers can deal with geographic SRS that have
latitude/longitude ordering and do the coordinate swapping, but not yet for
projected SRS that have northing/easting ordering.
The return of the driver is somehow correct. It reports a SRS in
northing/easting ordering and presents coordinates in that order. But I agree
it would be nicer for it to behave like geographic SRS with inverted axis
order.
Another way of working around that is to force VERSION=1.0.0, since GeoServer
only honours EPSG axis order from WFS 1.1.0. Remembers me
http://dmorissette.blogspot.fr/2012/12/dont-upgrade-to-wms-130-unless-you.html
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
