[gdal-dev] translate polygon shape file
Murat Beyhan muratbeyhan28 at gmail.com
Mon Mar 11 01:35:10 PDT 2013
Hi friends,
I have a polygon shape file which is including district of the city
It is latitude longitude data. And I try to transform it into UTM data
Is it possible to do using gdal.
I have googled it some but I could not find appropriate way to do.
The example of the data as follows.
Thanks for help....
Murat
Shapefile Type: Polygon   # of Shapes: 909
File Bounds: (      25.667,      35.820,0,0)
         to  (      44.869,      42.095,0,0)
Shape:0 (Polygon)  nVertices=156, nParts=1
  Bounds:(      34.833,      41.681, 0, 0)
      to (      35.213,      42.095, 0, 0)
     (      34.833,      41.691, 0, 0) Ring
     (      34.836,      41.702, 0, 0)
     (      34.838,      41.710, 0, 0)
     (      34.840,      41.719, 0, 0)
     (      34.842,      41.727, 0, 0)
     (      34.843,      41.736, 0, 0)
     (      34.845,      41.745, 0, 0)
     (      34.847,      41.753, 0, 0)
     (      34.851,      41.761, 0, 0)
     (      34.855,      41.770, 0, 0)
 ogrinfo -al tr_ilce_siniri_dd.shp|more
OGRFeature(tr_ilce_siniri_dd):908
  AREA (Real) =      0.013454
  PERIMETER (Real) =      0.538581
  ILCEDD_ (Real) =         910
  ILCEDD_ID (Real) =         931
  ILCE_AD (String) = MARMARA
  IL_KOD (Integer) = 10
  IL_ADI (String) = BALIKESIR
  POLYGON ((27.584554672241211 40.573818206787109,27.578886032104492
40.573699951171875,27.572929382324219 40.575611114501953,27.571149826049805
40.576972961425781,27.567972183227539 40.577934265136719,27.565275192260742
40.57794189453125,27.557207107543945 40.577068328857422,27.552865982055664
40.575958251953125,27.547388076782227 40.577339172363281,27.542625427246094
40.581424713134766,27.537281036376953 40.584625244140625,27.527751922607422
40.587604522705078,27.521244049072266 40.59442138671875,27.509946823120117
40.601016998291016,27.506982803344727 40.607612609863281,27.509469985961914
40.622554779052734,27.507785797119141 40.644989013671875,27.509929656982422
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130311/0c987dfc/attachment.html>
