[gdal-dev] Gdal Asynchronous IO
Allen Kempe allenck at windstream.net
Mon Mar 11 13:21:50 PDT 2013
In Rfc 24: GDAL Progressive Data Support it says that the metadata for a
driver will specify metadata item "DCAP_ASYNCIO" as yes if the driver
supports asynchronous IO. So, code like this should retrieve this option:
const char* s_asyncio = drv->GetMetadataItem("DCAP_ASYNCIO");
However, I have been unable to find any drivers that return "Yes".
So, is this the correct way to check whether a driver supports
asynchronous io?
Are there any drivers that currently support this besides Kadaku which I
don't have?
    Allen Kempe
http://acksoft.dyndns.biz/PictureGallery
298 W. Audubon Drive
Shepherdsville, KY 40165
+1 502 543-3438
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130311/31caa7e4/attachment.html>
