[gdal-dev] Error compiling GDAL from trunk on Mac OS X 10.6.8
Even Rouault even.rouault at mines-paris.org
Fri Mar 15 15:03:19 PDT 2013
Le vendredi 15 mars 2013 22:53:36, Jorge Arévalo a écrit :
> El viernes 15 de marzo de 2013 a las 22:36, Even Rouault escribió:
> > Le vendredi 15 mars 2013 20:09:57, Jorge Arévalo a écrit :
> > > Hello,
> > > I'm getting an error compiling GDAL from trunk (r25758). I successfully
> > > compiled GDAL from trunk before with this configure script:
> > > https://dl.dropbox.com/u/6599273/gdal/configure_gdal.sh
> > > But after last svn update to r25758, I get this error
> > > https://dl.dropbox.com/u/6599273/errors/gdal_trunk_compile_error.log
> > > I haven't compiled GDAL on Mac for a while. So, The problem isn't
> > > necessarily caused by the last update.
> > > Anyone else with the same problem?
> > Cool that someone tests on the Mac and reports.
> > Well, I assumed that "extern char** environ" that contains the
> > environment variable was available on all POSIX platforms, but
> > apparently not.
> > http://www.gnu.org/software/gnulib/manual/html_node/environ.html suggests
> > me the following patch. Please test and report if it works.
> > Index: port/cpl_spawn.cpp
> > --- port/cpl_spawn.cpp (revision 25734)
> > +++ port/cpl_spawn.cpp (working copy)
> > @@ -461,8 +461,13 @@
> > #include <signal.h>
> > #ifdef HAVE_POSIX_SPAWNP
> > #include <spawn.h>
> > +#ifdef MACOSX_FRAMEWORK
> > +#include <crt_externs.h>
> > +#define environ (*_NSGetEnviron())
> > +#else
> > extern char** environ;
> > #endif
> > +#endif
> > #if 0
> > > Thanks in advance,
> Thanks! We got to the same solution :-). I've found the same patch in
> MacPorts
> (http://trac.macports.org/browser/trunk/dports/lang/hugs98/files/patch-pac
> kages-base-include-HsBase.h.diff?rev=81676). It worked.
> I could create a new ticket and attach the patch file. Is it ok?
Or you can commit it directly as you wish since you've commit rights. But the
patch are not strictly identical. I tested #ifdef MACOSX_FRAMEWORK whereas the
link you provide test #ifdef __APPLE__ . Not sure if they are equivalent in
the GDAL context. Perhaps #ifdef __APPLE__ is better and MACOSX_FRAMEWORK too
specific to a special flavour of building a shared lib ? Just guessing
blindly...
> Jorge Arevalo
> Freelance developer
> http://www.krop.com/jorgearevalo
> http://about.me/jorgeas80
> Enviado con Sparrow (http://www.sparrowmailapp.com/?sig)
