[gdal-dev] Issues with FileGDB support
Jan Heckman jan.heckman at gmail.com
Sat Mar 16 00:49:02 PDT 2013
I have the gdb support working on a windows box, compiled 1.9.1, some time
ago.
>From memory:
Remember filegdb support is a plugin. The dll needs to be in a specific
gdalplugins directory.
I guess that if the support is compiled correctly and the dll is not found,
this would be mentioned in an error.
I had to edit nmake.opt; have to do that anyway for lots of support.
Lastly, when I built, there were 2 windows lib/dll's from esri (for
filegdb),  1 for vs 2008, and 1 for vs 2010.
Only the first works, which compelled me to compile using VS 2008.
If you have another vs version installed, you need to run the correct
vsvars.bat before starting (commandline) compilation.
FGDB_ENABLED = YES
FGDB_PLUGIN = YES
FGDB_SDK =
"D:\win7users\jan\Documents\Visual_Studio_2012\Projects\FileGDB_API_VS2008_1_2"
FGDB_INC = $(FGDB_SDK)\include
FGDB_LIB = $(FGDB_SDK)\lib\FileGDBAPI.lib
Specific supportfiles - see if these are compiled - are
in gdal-1.9.1\ogr\ogrsf_frmts\filegdb.
You should see ogr_FileGDB.dll and ogr_FileGDB.lib.
Let me know if this helps any.
Jan
On Fri, Mar 15, 2013 at 7:31 PM, Paul Norman <penorman at mac.com> wrote:
> > From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-
> > To: gdal-dev at lists.osgeo.org
> > Subject: [gdal-dev] Issues with FileGDB support
> > Hello
> > I have built gdal from source (1.9.2, latest stable) with Esri FileGDB
> > support included. This is specified during the configuration, --with-
> > fgdb=/usr/local/FileGDB_API/.
> > The configuration and build goes well and I can see that the fileGDB
> > libs get linked but when I check the format support with for example
> > 'ogrinfo --format' FileGDB doesn't show up. ldd shows that the binary is
> > linked to the fileGDB libs.
> > At this point I guess that the most likely explanation for this is an
> > error in the code, but I haven't checked it.
> > So, is FileGDB support working for you?
> It's been awhile, but I successfully built gdal with FileGDB support.
> My notes indicate I used ./configure --with-fgdb=/home/pnorman/FileGDB_API
> and installed files from that location to /usr/local/lib/libFileGDBAPI.so
> and /usr/local/lib/libfgdbunixrtl.so, as well as
> /usr/share/doc/filegdb-api/.
> I believe I installed from svn, and ogrinfo --version reports GDAL 2.0dev,
> released 2011/12/29
> gdal-dev mailing list
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130316/a8dff32f/attachment.html>
