[gdal-dev] C#-bindings and AccessViolationException
Tamas Szekeres szekerest at gmail.com
Sun Mar 17 23:06:43 PDT 2013
Markus,
Do you experience the same with a newer set of binaries, like with the
daily builds available at: http://www.gisinternals.com/sdk/ ?
Best regards,
Tamas
2013/3/18 markus.u.mueller <markus.u.mueller at zoho.com>
> Dear listers,
> I have troubles with the C#-bindings of GDAL. I use FWTools 2.4.7 on
> Windows XP 32bit, VS 2010 and .NET 4.0. When I try to run one of the
> GDAL-apps, GDALInfo.cs for example, I keep getting an Error saying
> "AccessViolationException was unhandled. Attempted to read or write
> protected memory. This is often an indication that other memory is corrupt.
> I stumbled upon bits and pieces of other people having the same problem
> but did not get a consistent idea what is behind the problem and how it can
> be solved. Obviously there are also 2 trac tickets that seem to be related
> to this problem.
> http://trac.osgeo.org/gdal/ticket/4049 and
> http://trac.osgeo.org/gdal/ticket/3249
> Any help would be appreciated,
> Markus
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130318/c5378ce9/attachment.html>
