[gdal-dev] What is the format of a .prf file?
Rainer M Krug r.m.krug at gmail.com
Wed Mar 20 08:01:47 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
I'm using gdalward in a script as follow, which works fine:
  FN=THERASTERLAYER
  gdalwarp -s_srs epsg:4148 \
           -t_srs "+proj=aea \
                   +lat_1=-28.25
                   +lat_2=-29.75 \
                   +lat_0=-29 \
                   +lon_0=30.75 \
                   +x_0=0  \
                   +y_0=0  \
                   +datum=WGS84 \
                   +units=m  \
                   +no_defs" \
            -dstnodata -9999 \
           $FN \
           $FN.gtif
What I don't like is that I have to specify t_srs in such a long way. It states that t_srs can be
"a .prf file containing well known text", but I can't figure out what a .pdf file is. Would for
exmple work, if I put
  +proj=aea
  +lat_1=-28.25
  +lat_2=-29.75
  +lat_0=-29
  +lon_0=30.75
  +x_0=0
  +y_0=0
  +datum=WGS84
  +units=m
  +no_defs
in t.prf and refer to it in gdalward as "-t_sts t.prf"?
Are there any examples available for prf files and allowed formats?
Thanks,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys.
(Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJRSc9bAAoJENvXNx4PUvmCqgwIANU0QD/rleq8jcEyYBoFh7mn
F/xD4gfKtoKV4FkPwzD7oKuSstCgTrbbm4scbHk3TQpajwWflEr9Rl5tqyHAFdDM
q3G/AQIqfYNRCdSzkb6ZchqTuFn22qDGnBy0Xfax398sIc/iucFO4Pa++X5WbN3d
dxIEGOtsMSWXkMlf7zwjubSqL77jJWVeyB6yBOOkqX5Nug3Y9PKdSFybws2zlCEQ
lpfoBxAbMlpmH8N9rN0Yw3zvJxaHjHG/dkjCZRMtLRMI7kcZ2STYoGO9OKB3uqkI
5Ps0NNYxNLbbah86UNzSrIc/3gIiBeotAQtRUfA+FkPbVAt1NnKIOio4TnrNmtk=
=vmS7
-----END PGP SIGNATURE-----
