[gdal-dev] What is the format of a .prf file?
Rainer M Krug r.m.krug at gmail.com
Thu Mar 21 01:08:58 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 20/03/13 16:44, Andre Joost wrote:
> Am 20.03.2013 16:01, schrieb Rainer M Krug:
>> What I don't like is that I have to specify t_srs in such a long way. It states that t_srs
>> can be "a .prf file containing well known text", but I can't figure out what a .pdf file is.
>> Would for exmple work, if I put
>> +proj=aea +lat_1=-28.25 +lat_2=-29.75 +lat_0=-29 +lon_0=30.75 +x_0=0 +y_0=0 +datum=WGS84
>> +units=m +no_defs
>> in t.prf and refer to it in gdalward as "-t_sts t.prf"?
> No, the proj definition text is not "well known text" WKT.
>> Are there any examples available for prf files and allowed formats?
> It's simply the same format as in every shapefiles .prj file.
> For example ogr2ogr -s_srs epsg:3375 -t_srs epsg:4245 Malay-Kertau.shp rivers-neu.shp ogr2ogr
> -s_srs epsg:3375 -t_srs Malay-Kertau.prj Malay-prj.shp rivers-neu.shp
> returns two identical outputs, where Malay-Kertau.prj contains the definition used in the first
> run with EPSG:4245.
Thanks for the response.
So the file Malay-Kertau.prj would then contain the text:
epsg:4245
So I have to put into the file simply the text as supplied to -t_srs ?
And what is the difference between a .prj file used by shape files and a .pdf file (format wise)?
Rainer
Rainer
> Greetings, André Joost
> _______________________________________________ gdal-dev mailing list gdal-dev at lists.osgeo.org
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys.
(Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJRSsAaAAoJENvXNx4PUvmCLCgH/2ZdL433Twrcvrmq0Nwz5HH7
osTxtve9AunR5nuNaMX9uyFihXjXbbMLf0gm8/8sZ3C4Z/tPb+9/vRvQYTD5cEPj
GTgDWboY7wg25IrDiWgYPpbiyZ3kkaXwmOmTCZeS03AzRtB15EQ/T/+77YHD7C99
Yg74pombMKHPYXbEeu5gAqGzP94eB0L0NlXaTqgeXhfo9uo6vo7JdPOQTTApYRml
Dh0jybjv783eItoFnW7P8MkOADx2AKpsu30KuWVuJX99WWw/353lqemG2jfJKRKW
1ZkakihyT1+d8rrvJv0vMPVOn3GvR0MrLluSLoLFrt5zGAtjKyVgUfRwom7Gfw4=
=TJnh
-----END PGP SIGNATURE-----
