[gdal-dev] Converting .NET Bitmap to GDAL Dataset
Tamas Szekeres szekerest at gmail.com
Fri Mar 22 13:12:16 PDT 2013
For an example of the reverse action see SaveBitMapDirect in
GDALReadDirect.cs<http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/csharp/apps/GDALReadDirect.cs>
To write data to GDAL dataset see:
GDALWrite.cs<http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/csharp/apps/GDALWrite.cs>or
GDALDatasetWrite.cs<http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/csharp/apps/GDALDatasetWrite.cs>
Best regards,
Tamas
2013/3/22 Maksim Sestic <max at geoinova.com>
> Hi all,
> Is there any example (or a hint) of converting a System.Drawing.Bitmap into
> GDAL Dataset?
> Regards,
> Maksim Sestic
> http://osgeo-org.1560.n6.nabble.com/Converting-NET-Bitmap-to-GDAL-Dataset-tp5042430.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130322/2e6e526d/attachment.html>
