[gdal-dev] Converting .NET Bitmap to GDAL Dataset
Maksim Sestic max at geoinova.com
Sun Mar 24 15:41:48 PDT 2013
Hi Tamas,
Yes, finally, "vsimem" works once bitmap is Png (abbreviated VB.NET code
follows):
      Dim bmp As Bitmap = Bitmap.FromFile("C:\Input.tif")
            Dim imageBuffer As Byte()
            Using stream As New MemoryStream()
                bmp.Save(stream, ImageFormat.Png)
                imageBuffer = stream.ToArray()
            End Using
            Dim pinnedArray As GCHandle = GCHandle.Alloc(imageBuffer,
GCHandleType.Pinned)
            Dim pointer As IntPtr = pinnedArray.AddrOfPinnedObject()
            Dim memFilename As String = "/vsimem/data"
            Gdal.FileFromMemBuffer(memFilename, imageBuffer.Length, pointer)
            Dim ds As Dataset = Gdal.Open(memFilename, Access.GA_ReadOnly)
            Dim drv As Driver = Gdal.GetDriverByName("GTiff")
            Dim ds1 = drv.CreateCopy("C:\Output.tif", ds, 0, Nothing,
Nothing, Nothing)
            pinnedArray.Free()
I've tested it on bitmaps originating from .bmp, .png, .tif and .jpg.
Regards,
Maksim Sestic
  _____
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Sunday, March 24, 2013 17:25
To: Maksim Sestic
Cc: gdal-dev
Subject: Re: [gdal-dev] Converting .NET Bitmap to GDAL Dataset
We could also convert the bitmap to png or some other formats that the GDAL
drivers reconise, something like:
        byte[] imageBuffer;
        using (MemoryStream stream = new MemoryStream())
            bmp.Save(stream, ImageFormat.Png);
            imageBuffer = stream.ToArray();
        Gdal.FileFromMemBuffer(memFilename, imageBuffer);
        Dataset ds = Gdal.Open(memFilename, Access.GA_ReadOnly);
Best regards,
Tamas
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130324/04118b91/attachment.html>
