[gdal-dev] import error on fedora?
Kyle Shannon kyle at pobox.com
Tue Mar 26 10:26:51 PDT 2013
Not a fedora guy, but you probably need the gdal-python package, try
installing python-gdal or gdal-python using yum.
kss
On Tue, Mar 26, 2013 at 11:18 AM, Chao YUE <chaoyuejoy at gmail.com> wrote:
> Dear all,
> I use "yum install gdal"  to install gdal on fedora 16,
> I can see all following commands in the terminal:
> ychao at lsce3139:~$ gdal
> gdaladdo        gdal_contour    gdalenhance     gdalinfo
> gdal_rasterize  gdaltransform   gdalwarp
> gdalbuildvrt    gdaldem         gdal_grid       gdalmanage      gdaltindex
> gdal_translate
> However when I tried to import gdal, I get import error:
> In [1]: import gdal
> ImportError                               Traceback (most recent call last)
> <ipython-input-1-27bf4694dd2b> in <module>()
> ----> 1 import gdal
> ImportError: No module named gdal
> In [2]: from osgeo import gdal
> <ipython-input-2-a04b80bf4e65> in <module>()
> ----> 1 from osgeo import gdal
> ImportError: No module named osgeo
> so what's going on here? thanks for any response.
> best regards,
> chao
> Chao YUE
> Laboratoire des Sciences du Climat et de l'Environnement (LSCE-IPSL)
> UMR 1572 CEA-CNRS-UVSQ
> Batiment 712 - Pe 119
> 91191 GIF Sur YVETTE Cedex
> Tel: (33) 01 69 08 29 02; Fax:01.69.08.77.16
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
