[gdal-dev] Gdal_translate terminated - buffer overflow detected
Even Rouault even.rouault at mines-paris.org
Thu Mar 28 10:04:35 PDT 2013
Selon Ondrej Chlup <chlup.ondra at gmail.com>:
> Hi,
> I was using GDAL version 1.9.1 to get NTv2 grid from raster in PostGIS
> using gdal_translate. I got the error: 0*** buffer overflow detected ***:
> gdal_translate terminated
> I was trying to use GDAL version 1.9.2 but with the same error. Is there
> any way how to fix it?
You are probably running into a knwown problem of the PostgisRaster driver
http://trac.osgeo.org/gdal/ticket/4703 that has been fixed in the dev version
(GDAL 1.10dev)
