[gdal-dev] GoogleEarth wont read KML files created by ogr2ogr: Unknown element <Schema>
Nikos Alexandris nik at nikosalexandris.net
Wed May 1 15:30:57 PDT 2013
Hi!
I work with GDAL 1.9.2, compiled from source with support for expat and KML
under Kubuntu 12.10.  Any attempt to convert a(ny) shapefile (be it of type
point or polygon) using ogr2ogr (or exporting from GRASS GIS or/and QGIS --
all based on the same GDAL librairies) results in a .kml file that Google-
Earth (version 7. ) wont read with the "excuse": Unknown element <Schema>.
Even the example KML file over at
<https://developers.google.com/kml/articles/vector> is rejected by GE with the
same error message.
Removing the <Schema> entries altogether, makes the file readable by GE.
Anyhow, GE reads without problems a KML example (that includes Schema
elements) to be found over at
<https://developers.google.com/kml/documentation/extendeddata> (look for the
Example under "Adding Typed Data to a Feature").
What are the odds?
Thank you, Nikos
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130502/d6c9b361/attachment.pgp>
