[gdal-dev] GoogleEarth wont read KML files created by ogr2ogr: Unknown element <Schema>
Nikos Alexandris nik at nikosalexandris.net
Thu May 2 00:09:53 PDT 2013
Frank Warmerdam wrote:
> Could you file a ticket, and attach a working and nonworking kml example?
Done.
> Any idea if this behavior varies across versions of google earth?
Not between ver. 6 and 7 under (K)Ubuntu at least.
> I wonder if libkml can read the file(s) ok.
As usual, lack of time and I (maybe wrongly) "suspect" that getting libkml
from SVN integrated in GDAL(-stable) is not easy.
Thank you, Nikos
[rest deleted]
