[gdal-dev] Adding labels / specifying styles
Alexandre Gacon alexandre.gacon+gdal at gmail.com
Thu May 2 08:38:26 PDT 2013
The shapefile format is not a format who supports styles and labels. It is
a data only format. So you can not associate labels to your points. You can
at most add a column with a text.
Regards
Alexandre
2013/5/2 Benoît Laurent <blaurent at heurisis.eu>
> Hello,
> I am a newbie with GDAL and OGR.
> I managed to create a shapefile following the provided sample :
> http://www.gdal.org/ogr/ogr_**apitut.html<http://www.gdal.org/ogr/ogr_apitut.html>
> The shapefile contains points. Now, I would like to associate labels to my
> points. I also wish to specify the size, the color of my points. Is it
> possible ? How ?
> Thank you very much in advance for your help.
> Benoît
> ______________________________**_________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/gdal-dev<http://lists.osgeo.org/mailman/listinfo/gdal-dev>
Alexandre Gacon
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130502/f811d646/attachment.html>
