[gdal-dev] Adding labels / specifying styles
Benoît Laurent blaurent at heurisis.eu
Thu May 2 08:45:52 PDT 2013
Thank you for your quick answer.
> Hi,
> The shapefile format is not a format who supports styles and labels.
> It is a data only format. So you can not associate labels to your
> points. You can at most add a column with a text.
That's what I have already done indeed.
After that, I am importing my shapefiles in QGis. Maybe, I should create
my labels using a Python script based on the added text column ?
Regards,
Benoît
