[gdal-dev] [GMT4] Messy little problem between GMT4, GDAL 1.9.2 and ArcGIS 10
John Helly hellyj at ucsd.edu
Sun May 5 14:04:52 PDT 2013
Hi.
A few years ago I had a problem with GMT/GDAL interactions such that the
GMT netCDF files were reflected when read into Qgis (for example). This
was worked around by running it through 'gdal_translate -of GMT'.  There
was also a discussion about this being a bug in something in GDAL (since
Qgis was using GDAL if I remember correctly) that was supposed to have
been fixed in some version (obviously don't remember the details). At
any rate, it stopped being a problem for me but now something else is
causing a problem in files that have the following workflow:
--> mbgrid (from MB-System) --> gdal_translate -of GMT --> ArcGIS netCDF
reader
Now I find that gdal_translate appears to be changing the header in a
way such that ArcGIS cannot read the netCDF.  The first 'ncdump -h'
below is what the header looks like before running through
gdal_translate and the second one is after gdal_translate.
I'm sending this note to MB-System, GMT and GDAL groups since it seems
like an issue of import to all three.  Any thoughts on this?
J.
=======================================Output from mbgrid before
gdal_translate ==================================================
ncdump -h MCBCP_BeachModel_UTM11N_Baseline.grdclip.nc
netcdf MCBCP_BeachModel_UTM11N_Baseline.grdclip {
dimensions:
     x = 12626 ;
     y = 12251 ;
variables:
     double x(x) ;
         x:long_name = "Easting (meters)" ;
         x:actual_range = 444057.827834802, 469309.046567392 ;
     double y(y) ;
         y:long_name = "Northing (meters)" ;
         y:actual_range = 3670183.00468016, 3694684.53612513 ;
     float z(y, x) ;
         z:long_name = "Topography (m)" ;
         z:_FillValue = NaNf ;
         z:actual_range = -1995.541015625, 599.818359375 ;
// global attributes:
         :Conventions = "COARDS/CF-1.0" ;
         :title = "Topography Grid" ;
         :history = "grdclip -V
/media/EXT4_Projects_01/SLR_Data/level1/MCBCP/Basemap/MCBCP_BeachModel_UTM11N_Baseline.grd
-G/media/EXT4_Projects_01/SLR_Data/level1/MCBCP/Basemap/MCBCP_BeachModel_UTM11N_Baseline.grdclip.nc
-Sa600/NaN -Sb-2000/NaN" ;
         :description = "\n",
             "\tProjection: UTM11N\n",
             "\tGrid created by mbgrid\n",
             "\tMB-system Version 5.3.1982\n",
             "\tRun by <hellyj> on <StonestepsLinux> at <Thu Apr 25
19:44:41 2013>" ;
         :GMT_version = "4.5.9_r9909 [64-bit]" ;
=====================================Output from mbgrid after
gdal_translate ====================================================
ncdump -h MCBCP_BeachModel_UTM11N_Baseline.grdclip.flipped.nc
netcdf MCBCP_BeachModel_UTM11N_Baseline.grdclip.flipped {
dimensions:
     side = 2 ;
     xysize = 154681126 ;
variables:
     double x_range(side) ;
         x_range:units = "meters" ;
     double y_range(side) ;
         y_range:units = "meters" ;
     double z_range(side) ;
         z_range:units = "meters" ;
     double spacing(side) ;
     int dimension(side) ;
     float z(xysize) ;
         z:scale_factor = 1. ;
         z:add_offset = 0. ;
         z:node_offset = 1 ;
         :title = "" ;
         :source = "" ;
John Helly, University of California, San Diego / San Diego Supercomputer Center / Scripps Institution of Oceanography / 760 840 8660 mobile / stonesteps (Skype) / stonesteps7 (iChat) / http://www.sdsc.edu/~hellyj
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130505/effe5e78/attachment.html>
