[gdal-dev] Can't build gdal in x64
Martin Chapman chapmanm at pixia.com
Mon May 13 11:20:23 PDT 2013
Mihaela,
You have to run nmake from the VC x64 command line window.
Goto:
Start Menu->All Programs->Microsoft Visual Studio 2010->Visual Studio
Tools->Visual Studio x64 Win64 Command Prompt (2010)
That will run the appropriate bat file for nmake and setup the x64
compiler options.  CD to your gdal dir then run nmake /f makefile.vc from
there.
Best regards,
Martin
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Mihaela Gaspar
Sent: Monday, May 13, 2013 12:15 PM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Can't build gdal in x64
More info on issue: I seem to build from VS but not from command line.
I put (to build in Win32)
!IFNDEF PLATFORM
PLATFORM=WIN32
!ENDIF
Modified to
!IFNDEF PLATFORM
PLATFORM=x64
!ENDIF
(to build in x64) - And it worked. But only if I build from inside Visual
Studio.
I would like to be able to use a bat file (and build alll
platform/configurations) The above - while it builds in VS, it will not
build from command line (with commands:
start /b /wait nmake -f makefile.vc clean
start /b /wait nmake.exe /f makefile.vc PLATFORM=x64
start /b /wait nmake.exe /f makefile.vc devinstall PLATFORM=x64
The exact same thing builds in Win32...
On Mon, May 13, 2013 at 8:53 AM, Mihaela Gaspar
<mihaela.gaspar at urbanrobotics.net> wrote:
I am trying to build GDAL (1.9.2) in x64.
In the instructions, I see:
# Uncomment the following if you are building for 64-bit windows
# (x64). You'll need to have PATH, INCLUDE and LIB set up for 64-bit
# compiles.
!IF "$(PLATFORM)" == "x64"
WIN64=YES
!ENDIF
And then, lower,
# Under win64, symbols for function names lack the underscore prefix
# present on win32. Also the STDCALL calling convention is not used.
!IFDEF WIN64
!UNDEF STDCALL
!ELSE
SYM_PREFIX=_
!ENDIF
Can't find a PATH, INCLUDE and LIB specific for x64, or anything else that
I should do...
I can build in Win32.
In x64, I get linker errors:
LINK : error LNK2001: unresolved external symbol _OGRFeatureStylePuller
LINK : error LNK2001: unresolved external symbol _OSRValidate
gdal19.dll : fatal error LNK1120: 74 unresolved externals
Please help.
Thank you.
Mihaela Gaspar
Urban Robotics Inc.
Software Engineer
33 NW First Avenue, Suite 200 | Portland, OR 97209
c: 971-269-9649
 <mailto:mihaela.gaspar at urbanrobotics.net>
 <http://www.urbanrobotics.net/> http://www.urbanrobotics.net
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130513/70f7575c/attachment-0001.html>
