[gdal-dev] Can't build gdal in x64
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon May 13 11:43:29 PDT 2013
On 2013-05-13 12:53 PM, Mihaela Gaspar wrote:
> In x64,I get linker errors:
> |LINK : error LNK2001: unresolved external symbol _OGRFeatureStylePuller
> LINK : error LNK2001: unresolved external symbol _OSRValidate
> gdal19.dll : fatal error LNK1120: 74 unresolved externals|
Note that before I switch from building GDAL from x32 to x64, I have to
rebuild *all* of the dependent libraries in x64 (this is the hardest
part of the whole process).
Also note to make sure that you run "nmake /f makefile.vc clean" before
each build.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
