[gdal-dev] Can't build gdal in x64
Mihaela Gaspar mihaela.gaspar at urbanrobotics.net
Mon May 13 12:03:44 PDT 2013
Thank you, this worked !!
On Mon, May 13, 2013 at 11:29 AM, Joaquim Luis <jluis at ualg.pt> wrote:
>  Mihael,
> To build with nmake command line all you need (plus the uncomment of x64)
> is to run the command from a command shell that has the apropriate
> variables set to build for 64 bits.
> For example, this is what I do to set up one 64 bits building environment
> (it's called from within another batch file)
> call "C:\Program Files (x86)\Microsoft Visual Studio
> 10.0\VC\vcvarsall.bat" amd64
> Joaquim
> More info on issue: I seem to build from VS but not from command line.
>   I put (to build in Win32)
> !IFNDEF PLATFORM
> PLATFORM=WIN32!ENDIF
>  Modified to
> !IFNDEF PLATFORM
> PLATFORM=x64!ENDIF
>  (to build in x64) - And it worked. But only if I build from inside Visual
> Studio.
> I would like to be able to use a bat file (and build alll
> platform/configurations) The above - while it builds in VS, it will not
> build from command line (with commands:
> start /b /wait nmake -f makefile.vc clean
> start /b /wait nmake.exe /
> f ma
>  kefile<
> /span>.vc PLATFORM=x64
> start /b /wait nmake.exe /f ma
>  kefile<
> /span>.vc devinstall PLATFORM=x64
>  The exact same thing builds in Win32...
> On Mon, May 13, 2013 at 8:53 AM, Mihaela Gaspar <
> mihaela.gaspar at urbanrobotics.net> wrote:
>>  I am trying to build GDAL (1.9.2) in x64.
>> In the instructions, I see:
>> # Uncomment the following if you are building for 64-bit windows# (x64). You'll need to have PATH, INCLUDE and LIB set up for 64-bit# compiles.!IF "$(PLATFORM)" == "x64"
>> WIN64=YES!ENDIF
>>  And then, lower,
>> # Under win64, symbols for function names lack the underscore prefix# present on win32. Also the STDCALL calling convention is not used.!IFDEF WIN64!UNDEF STDCALL!ELSE
>> SYM_PREFIX=_!ENDIF
>>  Can't find a PATH, INCLUDE and LIB specific for x64, or anything else
>> that I should do...
>> I can build in Win32.
>> In x64, I get linker errors:
>> LINK : error LNK2001: unresolved external symbol _OGRFeatureStylePuller
>> LINK : error LNK2001: unresolved external symbol _OSRValidate...
>> gdal19.dll : fatal error LNK1120: 74 unresolved externals
>>  Please help.
>> Thank you.
> *Mihaela Gaspar*
> *Urban Robotics Inc.**
> *Software Engineer
> 33 NW First Avenue, Suite 200 | Portland, OR 97209
> c: 971-269-9649
> http://www.urbanrobotics.net
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
*Mihaela Gaspar*
*Software Engineer
c: 971-269-9649
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130513/2d57c1b1/attachment-0001.html>
