[gdal-dev] What is the difference between gdal.lib and gdal.i.lib ?
Mihaela Gaspar mihaela.gaspar at urbanrobotics.net
Tue May 14 11:09:33 PDT 2013
Thank you.
On Tue, May 14, 2013 at 11:08 AM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> Mihaela,
> gdal.i.lib is a stub library wrapping the GDAL DLL.  Link against
> gdal.i.lib if you want to use the DLL.
> gdal.lib is a static library with everything in it.  Link against this if
> you want to avoid using the GDAL DLL.
> Best regards,
> Frank
> On Tue, May 14, 2013 at 10:11 AM, Mihaela Gaspar <
> mihaela.gaspar at urbanrobotics.net> wrote:
>> The devinstall option copies gdal.i.lib into the target library
>> installation folder.
>> I see another lib file created, gdal.lib
>> What is the difference between them ?
>> I I link statically, do I use gdal.i.lib ?
>> Thank you.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Software Developer
*Mihaela Gaspar*
*Urban Robotics Inc.**
*Software Engineer
33 NW First Avenue, Suite 200 | Portland, OR 97209
c: 971-269-9649
http://www.urbanrobotics.net
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130514/43aa10ef/attachment.html>
