[gdal-dev] What is the best way to test if a CPLString is not empty?
Thu May 16 11:07:28 PDT 2013
Jorge,
I don't believe oString.c_str() will ever be NULL.  You can use the
std::string empty() method to test if a string is empty (zero length).
  http://www.cplusplus.com/reference/string/string/empty/
CPLStrings have no equivelient to a NULL distinct from being a zero length
string.
Best regards,
Frank
On Thu, May 16, 2013 at 10:17 AM, Jorge Arévalo
<jorgearevalo at libregis.org>wrote:
> If I define a CPLString this way:
> CPLString osString;
> And I want to check if osString is not empty, what would be the best way?
> My bet:
> if (osString.c_str() == NULL)
> But I find it a little rusty... Is there any other better way?
> Many thanks in advance
> Jorge Arevalo
> Freelance developer
> http://www.krop.com/jorgearevalo
> http://about.me/jorgeas80
> Enviado con Sparrow (http://www.sparrowmailapp.com/?sig)
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130516/fc250408/attachment.html>
